I have a MDI Form where I can add several child forms by the items on a navigation bar. These childs can be draged within the parent form however a user wants to. What I need is to save not only the child forms, but also the layout, so that I'm able to load my layout and the forms afterwards in the same layout like before.
I use a storeTab event and a RestoreTab event which fire after using the mdimanager.saveAsXml() / loadFromXml(). Both events fire as often as the number of child forms I have opened in my parent form.
But the restoreTab event does not bring any effect. When I restart my application and call the Load method nothing happens. Is there any way to save the layout and the opened child forms so that I'm able to load both at a later date?
Thank You!
Alex
Hi Alex,
Please check out this help topic on saving and loading Tabbed MDI layouts.
This topic explains what conditions must exist in order for the layout to be loaded successfully.
