Is there any way how can I reset changes from end-user in UltraGrid layout (sorting, column order, column visibility) to the the original layout settings defined during design-time of the form.
You could also save the layout into a MemoryStream (and thus avoid creating files on the user's hard drive). Or you could even save it into the grid.DisplayLayout.Layouts collection.
Hi,If you want to preserve the original layout, you can save it as xml like this: this.ultraGrid1.DisplayLayout.SaveAsXml("WinGridLayout.xml");and when needed to restore the layout, you can load it from the xml file: this.ultraGrid1.DisplayLayout.LoadFromXml("WinGridLayout.xml");
Stefaniya
Developer Support Engineer
Infragistics, Inc
