165
Multiple field sorting and field collection property
hello all
need urgent help atleast from sm 1..as past 2 days i m stuglling for solution
i hv ultragrid on form ..and when i right click on it another form should open with 2nd ultragrid (till here i hv done)
-in 2nd grid field names should be in column 1,
you must not hardcode these field names but derive the field names from the recordset
-the display order in column 2,
-the sort type whether asc/desc in 3rd column,
-and the 4 col will be the sort order ,
the list of fields in this table should be automatically generated from the corresponding record set on which you right clicked.(in short when i right click on 1st grid 2nd grid should open which will allow me to choose fields and sort result in 1st grid..)
plz tel me how to proceedd with this.......
  • 469350
    There's no automatic way to do this, you will need to build a form that displays what you need. You could use a grid with an UltraDataSource and build the data source to have the columns and the data that you want and bind it to a second grid.
