125
ultraGrid1.CurrentState causes InitializeRow called
Hi, there:
I am using Infragistics UltraGrid v6.2.2. Inside grid_InitializeRow event handler I have the following line which causes the InitializeRow method called recursively.
UltraGridState s = m_grid.CurrentState;
Eventually, I got stack over flow exception. Can anybody tell me why?
I originally tried to color the cells and force the cells out of edit mode if the cells are in edit mode. The code is as the following:
private void m_grid_InitializeRow(object sender_, Infragistics.Win.UltraWinGrid.InitializeRowEventArgs e_)
    colorRow(e_.Row);
    if ((m_grid.CurrentState & UltraGridState.InEdit) == UltraGridState.InEdit)
      m_grid.PerformAction(
UltraGridAction.ExitEditMode, true, false);
     m_grid.ActiveCell = null;
This method throws stack over flow exception when I have a lot of rows in the grid. I found out the fault party is: m_grid.CurrentState
Any help is appreciated.
