185
How to pro grammatically add individual points on scatterchart
I am using a scatter chart and I was wanting to manually add individual nodes (points) instead of data binding.  I figured out how to do it with splinechart, but scatterchart does not like series.  And i can not figure out how to add nodes without using something like this :
Infragistics::UltraChart::Resources::Appearance::NumericSeries^ series = gcnew Infragistics::UltraChart::Resources::Appearance::NumericSeries();
series->Points->Add(gcnew Infragistics::UltraChart::Resources::Appearance::NumericDataPoint(values[j], times[j].ToString()->Substring(0,8), false));
series->Label = s;
ucLineChart->Series->Add(series);
Like i said, this works perfectly for spline charts but my only issue is that i need to show varying distances between points on the x-axis, so i was wanting to implement this code while using a scatter chart but apparently they do not support series, so how would i go about programtically adding nodes to a single line?
Thanks!!!
