519
Node text showing as node5 instead of actual text.
Hi , I am using a infragistics treeview control and binding the root node with the IList collection to display child nodes.
However I am facing some kind of weired issue.
 When I am adding a child node at  fourth level(Considering base as first level) , text is not appearing and its showing me as "Node5".
Further,its not showing the nodes added to it (Node5).I have checked in the datatable its showing all the data for the node properly.
If i add child nodes to the first child of base node , i dont see any issue......everything works fine.But the issue comes up when I try to add child node to Second child of root node.
I am not sure if I am binding the First child with the base node only....
Can you please help me with this??.
Ashish.
