Hi ,
I am using Custom contectmenu and Default context menu. when I right clcik on row it shows Custom context menu and when I click on
cell(I am using Fortmatted ) and right click I will see default contect menu with
cut/copy/paste/delete etc. The wiered thing is contecx menu showing Cut and Delete options as enabled some time and disabled sometimes.
I want to disable Cut and Delete options always.
Is there any way to handle Default ContextMenus menu items to disable.
There's no way to modify the default context menu. What you would have to do is apply a ContextMenu to the grid, thus overriding the default menu and you will have to implement all of the items you want on the menu yourself.
