i want to "hide" the subject and the description of specific appointments. In this case these are private appointments, which are displayed in other calendars as "busy".
My idea is an event, which will be raised before an appoitment is drawn.
Is there any possibility?
Changing the subject while loading from the database isn't really a solution, because the "private" flag is stored in the AllProperties byte array.
Greetings
Stephan
I have found a "half solution", but it doesn't work. The text wasn't changed, only the rotation works... What's wrong?
// <param name="parent">The UIElement-derived element whose child elements have been created.</param> public void AfterCreateChildElements(UIElement parent) { if (parent is Infragistics.Win.UltraWinSchedule.DayView.AppointmentUIElement) { UIElement text = parent.GetDescendant(typeof(EditorWithTextDisplayTextUIElement)); if (text != null) { ((EditorWithTextDisplayTextUIElement)text).Text = "Privat"; ((EditorWithTextDisplayTextUIElement)text).Rotated = true; } } }
