1060
MultiLine in DropDown Single Line in Display Member why ?
I have the following problem.
Using a UltraCombo, I am able to display an Image and some text.
In the InitializeRow I use this
     e.Row.Cells(KEY_CodeDescription).Value = String.Format("{0} {1}", C.Code, C.Description) & Space(1) & vbCrLf & String.Format("{0}", f.Nom)
To populate the dropdown list.  I get 2 lines which is what I want.
I also do this in the InitializeRow.. at the end...e.Row.Height = 50
In the initializeLayout i have added
e.Layout.Bands(0).Override.RowSizing = RowSizing.AutoFree
e.Layout.Bands(0).Override.RowSizingArea = RowSizingArea.EntireRow
e.Layout.AutoFitStyle = AutoFitStyle.ResizeAllColumns
e.Layout.Override.ColumnAutoSizeMode = ColumnAutoSizeMode.VisibleRows
e.Layout.Override.CellMultiLine = DefaultableBoolean.True
e.Layout.Bands(0).Columns(KEY_CodeDescription).CellMultiLine = DefaultableBoolean.True
However the display area shows everything in the same line.
Any ideas ?
