350
Error 2 Handles clause requires a WithEvents
VS2008
Infragistics 2009.2
Hi!
I have a problem with the VS2008 designer and Infragistics 2009.2 Wingrid...
In my appl (Vb.Net) I have a standard form with a wingrid inside (Framework built with C#). This is the form used as base for all forms in the appl... When I create a form inheriting from this standard form I can´t manage events from the editor...
I can see the grid and dbl-click on it... Doing this, an event its created:
Private Sub grdList_InitializeLayout(ByVal sender As System.Object, ByVal e As Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs) Handles grdList.InitializeLayout
So, the error appears:
Error 2 Handles clause requires a WithEvents variable defined in the containing type or one of its base types. c:\Proyectos\Proyect1\Sources\Net35\Administration\BrandForm.vb 30 153 Forms.Infragistics
Any idea?
Edit:
Important info...
The wingrid inside the standard form it is not an UltraWinGrid.
It is a grid base from the same framework, built outside the designer
as a simple class DataGrid.cs). It´s instantiated inside the standard
form as:
this.grdList = new CPCS.AppFwk.Controls.Infragistics9.DataGrid();
public CPCS.AppFwk.Controls.Infragistics9.DataGrid grdList;
Could this be the problem???
DataGrid.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Infragistics.Win.UltraWinGrid;
namespace CPCS.AppFwk.Controls.Infragistics9
    public class DataGrid : UltraGrid, IDataGrid
        IDictionary _prevColumnActivation;
        public DataGrid()
            _prevColumnActivation = new Dictionary();
            DisplayLayout.AutoFitStyle = AutoFitStyle.ExtendLastColumn;
            DisplayLayout.EmptyRowSettings.ShowEmptyRows = true;
            DisplayLayout.GroupByBox.Hidden = true;
            DisplayLayout.MaxBandDepth = 1;
            DisplayLayout.MaxColScrollRegions = 1;
            DisplayLayout.MaxRowScrollRegions = 1;
            DisplayLayout.Override.AllowAddNew = AllowAddNew.No;
            DisplayLayout.Override.AllowDelete = Infragistics.Win.DefaultableBoolean.False;
            DisplayLayout.Override.AllowRowFiltering = Infragistics.Win.DefaultableBoolean.True;
            DisplayLayout.Override.AllowUpdate = Infragistics.Win.DefaultableBoolean.False;
            DisplayLayout.Override.CellClickAction = CellClickAction.RowSelect;
            DisplayLayout.Override.HeaderClickAction = HeaderClickAction.SortMulti;
            DisplayLayout.Override.HeaderStyle = Infragistics.Win.HeaderStyle.WindowsXPCommand;
            DisplayLayout.Override.SupportDataErrorInfo = SupportDataErrorInfo.CellsOnly;
            DisplayLayout.Override.FilterUIType = FilterUIType.FilterRow;
        protected override void InitLayout()
            base.InitLayout();
        private Boolean _enabled;
        public new Boolean Enabled
            get
                return _enabled;
            set
                _enabled = value;
                ChangeEnableColumn(value);
        #region IDataGrid Members
        public void SetSortInformation(IDictionary sortInformation)
            sortInformation.Clear();
            foreach (UltraGridColumn column in DisplayLayout.Bands[0].SortedColumns)
                sortInformation.Add(column.Key, Helpers.DataGrid.ConvertSortIndicator2SortOrderOperator.Convert(column.SortIndicator));
        #endregion
        private void ChangeEnableColumn(bool enable)
            foreach (UltraGridColumn column in DisplayLayout.Bands[0].Columns)
                if (enable)
                    if (_prevColumnActivation.ContainsKey(column))
                        column.CellActivation = _prevColumnActivation[column];
                    else
                        column.CellActivation = Activation.AllowEdit;
                else
                    if (!_prevColumnActivation.ContainsKey(column))
                        _prevColumnActivation.Add(column, column.CellActivation);
                    else
                        _prevColumnActivation[column] = column.CellActivation;
                    column.CellActivation = Activation.NoEdit;
Daniel
PD: sorry my english!!
