I have the following problem.
I have a grid with 2 dropdown lists (valuelists)
Whenever I set the value of the 1 cell, this will filter down the values available in the second.
What I do now is repopulate the valueList.
However the problem is that once that is done, the others rows with different values in column 1 will not have the associated item to the column 2 value, and therefore the display member value will be missing and I only see the valuemember which means nothing to the end user.
My question is How do I keep the displayed member in the not active rows to show the description and not the ID.
Creating a dropdown list in a grid cell whose list values are dependent on another cell - Windows Forms - Infragistics Community
Instead of setting the cell column valuelist, set the cell valuelist itself.
