I am trying to add a UltraComboEditor control to a toolstrip control by using the ToolStripControlHost. The control does get added to the ToolStrip, but I am getting some odd behaviour. At the point where the control should be inserted I get the selection arrow which provides the other available controls for the toolbar. When I press the arrow I see the UltraComboEditor, so it has been added to the toolstrip.
Even when I add the UltraEditorCombo to the beginning of the toolstrip I am having this issue, so it is not related to the position of the control on the toolstrip. When I try it with a regular windows control there is no problem at all it seems to work perfectly.
The code I use is as follows:
Dim dropdownCheck = New Infragistics.Win.UltraWinEditors.UltraComboEditor dropdownCheck.DropDownStyle = Infragistics.Win.DropDownStyle.DropDownList dropdownCheck.CheckedListSettings.CheckBoxStyle = Infragistics.Win.CheckStyle.CheckBox dropdownCheck.CheckedListSettings.EditorValueSource = Infragistics.Win.EditorWithComboValueSource.CheckedItems dropdownCheck.CheckedListSettings.ItemCheckArea = Infragistics.Win.ItemCheckArea.Item dropdownCheck.Items.Add(New Infragistics.Win.ValueListItem("TestValue")) dropdownCheck.Items.Add(New Infragistics.Win.ValueListItem("TestValue2")) dropdownCheck.Items.Add(New Infragistics.Win.ValueListItem("TestValue3")) dropdownCheck.AutoSize = True Dim dropdownCheckToolStripControlHost As New ToolStripControlHost(dropdownCheck) ToolStrip1.SuspendLayout() ToolStrip1.Items.add( dropdownCheckToolStripControlHost) ToolStrip1.ResumeLayout()
I got back to this project recently and the problem was solved by using the latest service releases.
Your sample works fine for me in both 9.1 and 9.2. But I, of course, am using the latest service release for both.
A difference I noticed was that in your original app the 9.1 version was used and that I am using the 9.2 version. Is it possible that the differences come from that?
So you are saying that if you run the sample that you attached here, you initially do not see the UltraComboEditor, but instead you see a space and the overflow arrow. Which is the same thing I see.
But when you make the form wider, the UltraComboEditor is not appearing in the correct place on the ToolStrip, but is instead appearing in the upper left?
Those are not the results I get - the UltraComboEditor shows up right where it is supposed to on my machine.
So this must be a problem specific to your machine. It seems unlikely, but perhaps there was an issue with the UltraComboEditor which has been fixed and you are just using an older version. Try getting the latest service release and see if that helps.
When I add a normal windows combobox and set it's size to be too large to fit on the toolstrip I do get the arrow button. When I resize the form to be wide enough the control jumps into place. When I try making the form wider while the UltraComboEditor is on the toolstrip it does not jump into place, but instead it remains under the button, no matter how wide I make the form.
