I have a need to size all of my grid's columns to the width of the header text or longest cell text... whichever value is greater.
Currently, I am looping through all of the columns in my grid and I call the following method to size each column:
column.CalculateAutoResizeWidth(PerformAutoSizeType.VisibleRows, true)
I used to use the "PerformAutoSizeType.AllRowsInBand" parameter, but I came across a case where I had too many rows in the grid and the resize routine took too long.
The "PerformAutoSizeType.VisibleRows" parameter works, but I think this only works on the few rows at the top of the grid that are visible. Is there a method that I can use that will base the resizing on a given number of rows in the grid... like the first 100 rows?
Thanks!
Steve
That's what I needed, thanks!
Hi Steve,
FYI, switching to CalculateAutoResizeWidth from PerformAutoResize was not neccessary. Both of these methods take a PerformAyutoResizeType. So you could have just passed in VisibleRows into PerformAutoResize and saved yourself a step.
Anyway... there is also an overload of PerformAutoResize which allows you to pass in an integer representing a number of rows, so you can pass in 100.
