I am trying to export an UltraWinGrid. The grid has currencies. Some are smaller and some are larger in with the format of ("#,##0;(#,##0)";) When I export to excel some values are not exported as numbers which are larger like (2407390997). Excel is treating them as string instead of numbers. I have done the formatting also in the CellExported method but even that doesn't help.
Any help is much appreciated.
Ram
Try setting the value type of the column to double. Its possible the numbers are too large for the column's data type and the grid, not the export process, is automatically converting the numbers to strings. Also, numbers are stored in the workbook file as doubles anyway, so they will eventually be converted to this format before exporting.
