I can't get the animation to play when the ActivityIndicator is added as a RenderingControl on a Grid's column. Only when hovering over a row the animation updates and stops. Any ideas which property of the Activity control could I use to set as the controlContainer.RenderingControlPropertyName so it would play the animation all the time it's enabled??
Thanks!
Hi Georgi,I have the same problem.I add the UltraControlContainer and the ActivityIndicator to a grid cell at runtime.This is done by a multithreadded process and is added to various rows as well as is removed from those rows afterwards in parallel.
I checked your sample and understand what you are doing there.Honestly, I have a bad feeling having a timer refresh the complete grid every x ms.Is there a problem with this approach or is this the common way to deal with this situation?
I noticed that the window is flickering when beeing dragged around (my app is not blocking the UI so this is not really great).
any help is kindly appreciated,best regardsAndy
One possible solution is to use a "Timer" to refresh the grid. By this way it is not necessary to hovering over the row to update the animation. I attached small example. If you have any questions do not hesitate to ask me.
Regards
Georgi
