I'm not having much luck having my columns automatically resized. My ultratree is freeform and I create columns and populate data on the fly. Columns are added to ColumnSet on node's Override. I tried doing ultraTree1.columnSettings.AutoFitColumns = AutoFitColumns.ResizeAllColumns; but this does nothing at all. Tried calling PerformAutoResize on columns in Node's Override ColumnSet also to no effect. Clearly I'm missing something here. Please help.
// Autosize the columns foreach(object obj in this.configTree.ColumnSettings.ColumnSets.All) { UltraTreeColumnSet columnSet = (UltraTreeColumnSet)obj;
// Autosize the columns foreach (UltraTreeNodeColumn col in columnSet.Columns) { col.PerformAutoResize(); } }
I am using WinTree ViewStyle.Default. My Infragistics version is 2007 Vol 3 .NET 2.0
My columns are NOT auto resizing to display the entire cell value.
I have tried
column.PerformAutoResize(Infragistics.Win.UltraWinTree.
ColumnAutoSizeMode.AllNodes);
AND tried
columnSet.Columns[attribute.Name].PerformAutoResize(Infragistics.Win.UltraWinTree.
Please help!
Jean-Claude
I am experiencing the same issue. I am using WinTree ViewStyle.FreeForm. My Infragistics version is 2007 Vol 3 .NET 2.0
I have to use ViewStyle.FreeForm and all my columns must have width size large enough to view the column rows/data.
Thanks Brian, I just noticed that small remark at the bottom of help info too.
So how do you suggest I handle column size issue in Freeform tree? What's the best way to implement auto resize?
AutoFitColumns is only applicable when using the OutlookExpress ViewStyle.
http://help.infragistics.com/Help/NetAdvantage/WinForms/2009.1/CLR2.0/HTML/Infragistics2.Win.UltraWinTree.v9.1~Infragistics.Win.UltraWinTree.UltraTreeColumnSettings~AutoFitColumns.html
