I have a problem in validating controls placed on different TabPages of an UltraTabControl.
Here is an example. I have a form with an UltraTabControl with 2 TabPages. On each TabPage there is an UltraTextbox binded to the same UltraValidator.
The two UltraTextbox are mandatory, so you must fill them with a value or the Validation won't success.
The problem is when, for example, I am on the second Tab and the first Textbox is empty. In this case, when i click on the Check button, the Validation doesn't have success but the MessageBox error is not shown, so actually anything doesn't happen.
Obviously I'd like that the Messagebox error would be shown, regardless of the tab I am when the Check Button is pressed.
Just as an information, the two textbox belong to the same Validation Group and the version of the library is 8.3
Claudio Di Flumeri
Hello Claudio,
Could you please try setting the following in order to achieve the desired behavior:
ultraValidator1.ValidateHiddenControls = true;
Please do not hesitate to ask if something comes up.
I am having the same issue with UltraValidator and UltraTabControl but there does not seem to be a ValidateHiddenControls property. I am using v10.3. Am I overlooking something?
Hello ebridges,
I tested this and you are right. I also tried it with the latest service release of 10.3 and the property is available. So I suggest you to download this service release and try again.
Please do not hesitate to contact us if you need any additional assistance.
