540
Emulating a simple winform listbox
Hi
I have a regular windows listbox to which I add items in a single column format as below;
 MyListBox.Items.Clear()
 MyListBox.Items.Add(x)
I am also able to delete items as below;
 MyListBox.Items.Remove(MyListBox.SelectedItem)
My question is how do I achieve the same effect ie a single column list and add and delete items from it in the equivalent Infragistics winform control?
Regards
  • 69832
    Suggested Answer
    You can use the UltraListView control with the following property settings:
    UltraListView.View = UltraListViewStyle.List;
    UltraListView.ViewSettingsList.MultiColumn = false;
    The syntax for item removal is similar, although there is no SelectedItem property because the control supports multiple selection (see UltraListView.SelectedItems collection).
