990
DockManager ChildPaneStyle modification
Hi!
I use UltraDockManager in Infragistics Windows Forms 10.1 version. I save everything that changes on the form in a database. I found in another post how to detect when a control is dragged to another area (AfterDockChange event). My problem is when I have two controls docked left for example with an horizontal split. Then I drag the first one to create a tab group with the second one. I tried a lot of things and I'm never able to find where the ChildPaneStyle is modified to save the changes in my database.
For your informatiomn, I cannot use the save/load functionnality. Is anyone knows how to detect the ChildPaneStyle modification ?
Best regards,
Benoit
  • 44743
    The AfterDockChange event will be fired when you take one pane and group it with the other in this scenario. You will just have to see if the ChildPaneStyle of the changed pane's group has changed since the last dock change occurred.
