739
Displaying Axis Value less than 1
Problem1
      I am working in Windows Application with UltraChart.
     I face a quit simple problem but I could not solve this.
     I want to display Y-Axis values less than 1 ( For Example 0.25, 0.35, 0.45, 0.005 etc )
    But it displays only 00 when displayed.
    I tried with LogBase Property set to 1.000001. But its showing the same output.
   Can u give solution in this Regard.
Problem2
    I want to display the Y-Axis plotting from Right to Left. By Default its displaying Left to Right.
    How can I solve this issue.
Thanks and Regards
Maguesh.
  • 26458
    Check the chart.Axis.Y.Labels.ItemFormatString property. If you set it to <DATA_VALUE> it should display all the decimal places. If you wanted to format the label with up to 3 decimal places you would set the ItemFormatString property to <DATA_VALUE:0.###>
    Reversing the chart axis is currently not possible. For this you can submit a feature request to our developer support group using this link: http://ko.infragistics.com/gethelp
