430
UltraMonthViewSingle appointments in first column are not selecting
Hi.  I have an ultramonthView single control and it seems that the appointments in the first column (sunday) are not selecting.  The first one i click  gets the highlighted circle with the 2 small white squares on each side.  all is well.  but from then on no other appointment gets selected.  Yes i have selecttypeday set to extended, and selecting appointments works in other columns of the control just fine.  Another weird thing is that i can select an appointment in the first column, then ctrl + click another appointment in another column to select it, then i can ctrl+click back in the first column and that appointment selects correctly. So as long as you go back and forth its ok.  Its a weird issue.  Anyone know of this?
I tried to attach a problem steps recorder file but it was too big.
Any help is greatly apprectiated.  Thanks.
