Hi All, Does anyone knows about WinGrid option which allows to add column with sequence for each displayed row in WinGrid ? I do not want to add an extra column and separate code to provide valid sequence. I have seen solution for this somewhere but right now I can not find it. Any help would be appreciate Piotrek
Hi Mike,
This is what I was looking for !!!!
Cervesa for you ;)
Piotrek
If by "sequencing", you mean row numbers, you can use the RowSelectorNumberStyle property on the Override object to have the grid automatically display row numbers in the row selectors. Just make sure the RowSelectors are visible using the RowSelcetors property.
hi,
I am not getting anything. My question is if it is possible to use some existing functionality of WinGrid to do this ?!
Regards
are you getting column out of sequence mean order is not as per your need or as per stored procedure.
