We were using the AfterSelectChange Event to know when a record is selected. Problem is there are instances when they need to click the same row again, so trying to move to the Click or MouseUp Event, but that fires on header click as well. I'm using some code to determine if it's a row click and it works as opposed to open space below rows, but still counts the header as the first row.
I need to have an event(whatever event) fire and only run if an actual row is selected, not the header. I feel like I'm missing something right in front of me.
I tried using this in the MouseUp event
Infragistics.Win.UIElement aUIElement= dgOpen.DisplayLayout.UIElement.ElementFromPoint(new Point(e.X, e.Y)); UltraGridRow aRow= (UltraGridRow) aUIElement.GetContext(typeof(UltraGridRow)); // if a row was found display the band and row index if (aRow != null) {
Which gets me a good chunk there, but still includes the header.
One thing to note is that you won't get a MouseUp if the cell goes into edit mode on the MouseDown. If you can handle MouseDOwn instead, you can use the ElementFromPoint method to hit test for a CellUIElement, which will filter out hits on the row selector, like so:
void ultraGrid_MouseDown(object sender, MouseEventArgs e){ UltraGrid control = sender as UltraGrid; UIElement controlElement = control.DisplayLayout.UIElement; UIElement elementAtPoint = controlElement != null ? controlElement.ElementFromPoint( e.Location ) : null; UltraGridRow rowAtPoint = null;
while ( elementAtPoint != null ) { CellUIElement cellElement = elementAtPoint as CellUIElement; if ( cellElement != null ) { rowAtPoint = cellElement.Row; break; }
elementAtPoint = elementAtPoint.Parent; }
if ( rowAtPoint != null ) { // TODO: You are here. }}
