65
show custom tool tip on cell active
Is it possible to show a custom tool tip when the focus is in the cell, as the user navigates through a grid using the keyboard using the tab key?
  • 469350
    Suggested Answer
    The code posted here probably won't work, since the tooltip won't show up unless the mouse hovers over a cell.
    If you want to force a tooltip to show up based on the current active cell, then you could use the UltraToolTipManager component and call the ShowToolTip method in the AfterCellActivate event of the grid.
  • 918
    I would use the after cell activate event and do a select statement for the column header text.  Once you have that then just assign the tooltip text.
    Something like this:
    Dim
    aColumn As UltraGridColumn
    aColumn = aUIElement.GetContext(
    GetType(UltraGridColumn))
    If Not aColumn Is Nothing Then
    Select Case aColumn.Header.Caption
    Case "Name"
    Select Case color
    Case "Color [Teal]"
    If aRow.IsActiveRow Then
    aRow.ToolTipText =
    "This Customer has a contract that is fast track. " & sActiveRow & ""
    Else
    aRow.ToolTipText =
    "This Customer has a contract that is fast track."
    End If
    End Select
    End Select
    End If
