I am trying to get DisplayLayout.LoadStyle = LoadStyle.LoadOnDemand working on my grid.
I create a DataSet that contains a number of DataTables linked by DataRelations. If I set the DisplayLayout.LoadStyle = LoadStyle.PreLoadRows, the grid automatically displays the data with (+) and (-) indicators to expand/collapse rows that have child rows. Ok so far.
[Now, I set the DisplayLayout.LoadStyle of the grid set to LoadStyle.LoadOnDemand. The reason I want to try LoadOnDemand is that if I have more than 8 DataTables in the DataSet the grid starts responding very slowly. ]
I create the DataSet and set the DataSource of the grid to the DataSet. When the screen finally loads nothing shows in the grid. The correct data is in the DataSet. What else am I missing here?
I can't see any reason why setting the LoadStyle would cause the grid to be completely blank. LoadStyle will not, in fact, have any effect on the root-level rows in the grid. Are you sure you are not changing anything else?
