60
UltraChart Binding problems:
Using:  VS 2008, C#.net
I am trying to use the UltraChart object to bind to a datatable in code as follows:
void UpdateQualityChart(object sender, EventArgs e)
   DataTable dt = new DataTable();
   dt = _sqlData.CreateQualityDataSet();
   uChtQuality.DataSource = dt;
   uChtQuality.Data.DataBind();
   dt.Dispose();
I have verified that there are 10 rows of data in the table.
I created the chart by dragging and dropping on the form (not in code).
There are no errors and my project builds/runs without warnings or errors but the chart just
shows the standard "Data Not Available" message.
Any example code/project would be appreciated.
  • 2406
    The DataSource of the chart is a reference to the DataTable you create and when you Dispose it (the last line of your code), you indeed dispose the DataSource of the chart. You just do not have to dispose the table and will not have a problem.
