170
Scrollbar Problem in TabbedMDIManager
Actually I have TabbedMDIManager in my MDIForm. When i open the Child windows in my MDIForm, all the child windows opens perfectly with scrollbars  when MDIForm is not in Ribbon view. The scrollbars are also visible above the TabbedMDIManager (in the Child Form).
When I add the ToolbarsManager and changed my MDIForm's view as Ribbon view, the MDIChild windows are opening same as before with scrollbars. But the scrollbars are below the TabbedMDIManager. But the form is scrolled by using the scrolling wheel from mouse.
Can anyone give me a suggestion to solve this issue??
Johnson (JSN)
  • 615
    Hello Johnson,
    Was the sample that I sent you helpful? Did you solve the issue?
    Sincerely,
    Matteo
    Developer Support Engineer
    www.infragistics.com/support
  • 615
    Hello Johnson,
    Attached is a sample that I created trying to riproduce, without succeding, the issue you are describing.  The sample works fine. I am not clear on what you are trying to achieve, and in your use of the tools.
    Please try to run the sample and, if it is not what you were talking about, apply changes that can lead to the result you already have in your program, then send us back the new sample, so that I can have a clear understanding of the issue.
    Sincerely,
    Matteo
    Support Developer Engineer
    TabbedMDIManager.zip
  • 44743
    I was not able to reproduce this in a sample, but it sounds like it may be a bug. I have forwarded this post to the Developer Support Manager and a DS engineer will be contacting you about this issue.
