Hi
I am using Ultra timeline view.
I have a panel in left side which shows me pending job, I want to drag this into time line view and assign that job to the Employee (which are appearing on vertical side)
I am able to drag this, but the problem is how can I open the calendar on the drop event in which I can assign enter the information for that job and also what is the procedure to add some codes when user press the "Save and Close" button in the assignment form
Also I have set databinding of owner but the first rows shows unassigned, please tell me how to remove this row
Thank you very much
Yes problem has been solved
Thanks for your help
Hi Atif,
Were you able to resolve the issues you have mentioned in this post or do you have any questions with this matter?
NehaDeveloper Support EngineerInfragisticswww.infragistics.com/support
atifamin2002 said: how can I open the calendar on the drop event in which I can assign enter the information for that job
atifamin2002 said:but the first rows shows unassigned, please tell me how to remove this row
