I am trying to change the way my labels are showing up on a LineChart. Right now the value on each point displays the decimal value I supplied. I am trying to format each point to have "<Decimal Value> (55.5%)" Where 55.5% comes from a calculation. Thanks!
I just wanted to know if you were able to change the Label Format using the ItemFormatString following the Petia’s suggestions or you still need help? Just let me know.
Thank you.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
Try using the ItemFormatString property of the corresponding axis:
chart.Axis.Y.Labels.ItemFormatString property.
If you set it to <DATA_VALUE> it should display all the decimal places. If you wanted to format the label with % you would set the ItemFormatString property to <DATA_VALUE:##.#%>.
