Is there a way I can show summaries when the group of rows is collapsed? Our customers often want to see just the column summaries before they drill down to the specifics.
I just wanted to know if you were able to show the summary when is collapsed following the Mike’s suggestions or you still need help? Just let me know.
Sincerely,DimiDeveloper Support EngineerInfragistics, Inc.
We are experimenting with these solutions. We will most likely post a solution to this if we come up with something flexible.
Thanks for your input.
It depends what you mean by "group of rows".
If you are using OutlookGroupBy, then summaries display inside the GroupByRow by default, so you don't have to do anything.
If you are displaying hierarchical data in the grid, then there's no built-in way to do this. The summary rows is always under the parent row and therefore collapsing the parent hides the summaries. In this case, you might be able to work around the issue in a couple of ways.
