I have created an UltraGrid control that allows users to enter and decimal values. When the decimal values are in edit mode they show as decimal, but when the user leaves, they show as currency.
The problem that I am experiencing is that after I edit one cell, when I go to the other in edit mode, the decimal value is displayed for one second and then it reverts to the currency format, without leaving the cell and still in edit mode.
I would like to know what can I do about this problem.
I suggest you to use the "Format" property of each column. For example if you want to set your coulmn in decimal format, you could set property "Format = D", if you want the column to be in currency format , then set "Format = C".
Regards
georgi
