HI,
When I click on a node with the mouse and try to drag in the same physical operation it does not work. I have to click on the node, let the mouse button go, then click again and THEN it will drag.
In the above situation, if I click on the first node and it won't drag , then click again on ANOTHER node that other node will drag.
I have a mouse down event, but it checks for a right click and if there is one it sets that node to be active.
Thanks.
Thanks, works great.
Try setting the UltraTree.Override.SelectionType to 'ExtendedAutoDrag'
