210
Which appearance should I change?
I've heavily customised the colours of my WinGrid including the colour of the scrollbars, but there's a grey rectangle that appears in the bottom-right corner of the grid when both scrollbars are visible.  Which appearance do I need to change/override in order to make that rectangle blue?
Here's a screenshot... I've drawn a red X in the rectangle whose colour I wish to change.
Andy
  • 469350
    Verified Answer
    Hi Andy,
    What you are looking at here is the ScrollbarIntersectionUIElement. There aren't any Appearance properties that affect this area, but you can set it's color in a number of ways.
    One way to do this is via Application Styling. But it would be a lot of work to use AppStyling just to style one tiny little element like this.
    Another option would be to use a DrawFilter. This is much easier. Here's some sample code.
        public class MyDrawFilter : IUIElementDrawFilter
            #region IUIElementDrawFilter Members
            bool IUIElementDrawFilter.DrawElement(DrawPhase drawPhase, ref UIElementDrawParams drawParams)
                if (drawParams.Element is ScrollbarIntersectionUIElement)
                    switch (drawPhase)
                        case DrawPhase.BeforeDrawBackColor:
                            drawParams.AppearanceData.BackColor = Color.Blue;
                            break;
                return false;
            DrawPhase IUIElementDrawFilter.GetPhasesToFilter(ref UIElementDrawParams drawParams)
                    return DrawPhase.BeforeDrawBackColor;
                return DrawPhase.None;
            #endregion
    You assign the DrawFilter to the grid like this:
    this.ultraGrid1.DrawFilter = new MyDrawFilter();
    You can do this in the form constructor or in the Form_Load.
