Hi Everyone,
is there a possibility to remove any space beteween groups when they're collapsed?
I already set GroupSpacing and any margins I could find and think of to 0, but there is still a little space left between those Groups.
Any help would be greatly appreciated.
Greetings, andre.
Hi Gianni,
thank you very much for your tip, it solved my issue with the spacings too.
Greetings, xdolving.
I finally solved the issue setting the property UseLargeGroupHeaderImages to false.
Bye
Gianni
Ciao!
I'm experiencing the same problem, if I set GroupSpacing property more than 10 I can see the space growing, but between 0 and 10 pixels nothing change, a 10 pixels gap always remains ...Are there other properties to check?
Thank you in advance
Thanks for the reply Ian.
I tried setting them to 0 and Horizontal spacing between those Groups is still more than 0.
Greetings,
andre
Xdolving-
Did you check the ItemAreaInnerMargins & ItemAreaOuterMargins w/in the UltraExplorerBar Designer? They are located under "Settings" for each Group.
Just a thought.
-Ian
