515
Export to Excel Hang - Reproduceable
I know this has been posted a few times but we finally have a repeatable set of steps to make this happen and have boiled it down as far as we could.
Attached is a small project that has a sample dataset in it with a WinGrid.  Build and run the app and there are some instructions at the top of the form:
Group By Clinic Column, Sum the Charges Column, Filter Account Type to be "Workers Comp" and then Export the project.
It seems this is the lethal combination.
This was built with 9.2 SR 2035 and SR 2074, both exhibit the same behavior.  It does however work if it is built with 6.3 SR 1059.
GridExportIssue.zip
