460
Item Text
Im trying to change the text property of an item before it is added in the items collection of the ultralistview, but it is read only. The text that the item uses is the key string value of that item. How can I change an items' text property programmatically in ultralistview?
  • 69832
    As you point out here the Text property is read-only, so you cannt change it without changing the Value property. One approach to having different item text is to create a wrapper class that overrides ToString, and assign the item value to that instance, and from ToString return the string you want to display.
