Hi, I need to merge in the main menu of the application some menuitems that are specific to a control inside the main form. If this control is visible the menu items must be visible if the control is not instantiated or invisible items in the menu are not available.
What I've tried is to initialize ToolButtons and StateToolButtons in the control, that implements an interface with 2 methods: the first to get the menu and the second to handle menu actions. When the control is visible the Toolbuttons are added to the main UltraToolbarsManager, when is hidden or removed it removes the items from the UltraToolbarsManager. This works fine even if I'm not sure is the best way to handle this. The problem is that I don't know how to manage OptionSets in this scenario: in the examples I found is always the UltraToolbarsManager thar creates the OptionSet but in my Initialization method of the control I don't have a reference to the UltraToolbarsManager; is the main form that performs the merge when it is the time. How can I specify in the control the behavior of my menu items and then merge them to the main form menu when the control is instantiated?
Alessandro
Hello Alessandro,
I see that Mike provided an answer to your issue. If his answer solved your issue, please verify it as the answer.
Is it possible to change your initialization method to pass the UltraToolbarsManager into it? That way, you could add OptionSets directly to the UltraToolbarsManager. If not, you could create the OptionSet manually and add it. There is a hidden Add method on the OptionSets collection which takes an OptionSet. It is used internally by our code, but you should be able to use it for this.
As for the stack overflow, it is correct for the ToolClick to fire again when the Checked value is changed on menu items. You would have to use an anti-recursion flag in your code to ignore the ToolClicks which occur in response to your own code.
Oh, I forgot! When I'm tying to handle manually the alternative checked/uncheched of the menu items that are in the logical OptionSet, by setting the Check property but this seems to fire the ToolClick evet again and goes in loop till a stack overflow...
Regards Alessandro
