95
Appending pages to an existing report saved as XML
Is it possible to load a previous created report using the Load function of the report
eg. :
Report Doc = new Report
Doc.Load("text.xml")
Now when you add a section is added to the front of the report. I want to append to the end of the loaded report.
How do i do this ?
Thanks in advance,
 P. Ruedisueli
  • 469350
    Verified Answer
    I don't understand your question. If you load a report from a file and add a section, the new section is added on to the end of the report, not the beginning. There is no way to insert a section at the beginning, the Documents engine only allows you to add to the end.
    I tested this out and it works fine for me.
    I'm attaching my sample project here so you can take a look. Push button 1 and you get a report with one section. Push button 2 and it loads the saved report file and adds a second section to the end.
    WindowsFormsApplication29.zip
