I'm using Infragistics 2008.2.
I want to know if it is possible to implement a grid like the picture below. There are a lot of groups and columns and the grid is a little narrow, so I want to show the column headers on the left side instead of the top side.
I tried card view, but it does not support groups.
Hello Matteo,
Currently all I need has already been discussed above.
It seems that currently what I can do is waiting for the new requirement to be implemented in the next version of infragistics.
Thank you!
Is there anything else you need regarding this matter?
Sincerely,
Matteo
Developer Support Engineer
You could copy the data from your data source into a different object, like an UltraDataSource, for example, in the appropriate structure and bind that to the grid. But the grid will still treat the columns and columns and rows as rows. So there's no UI in the grid to allow the user to add a column, for example. So this would only work if you have a fixed number of rows.
Thank you for your support.
Currently do you have any suggestion to get a similar look of the grid as what I wanted? Basically my situation is that the grid is too narrow to put all groups and columns horizontally. I'm also thinking about some workarounds like using ultratree but it seems a little complicated.
Hello Wan,
After some research, this issue has been determined to be a new feature request. I have sent your feature request directly to our product management team. Our product team chooses new feature requests for development based on popular feedback from our customer base. Infragistics continues to monitor application development for all of our products, so as trends appear in requested features, we can plan accordingly.
We value your input, and our philosophy is to enhance our toolset based on customer feedback. If your feature is chosen for development, you will be notified at that time. Your reference number for this feature request is FR12423.
If you would like to follow up on your feature request at a later point, you may contact Developer Support management via email. Please include the reference number of your feature request in the subject and body of your email message. You can reach Developer Support management through the following email address: dsmanager@infragistics.com
Thank you for your request.
