I have an ultrawingrid. On some condition entire grid is set disabled [needs to make grid uneditable, so i used UltraGrid1.Enabled= False.]
But now requirement changed. I need to make entire row readonly. And If click on cell , i want events to occur. Right now no events occuring and my most of the codes are in AfterEnterEditMode or AfterExitEditMode. But these two events aint firing as i made rows Activation = Activation.NoEdit.
So any workaround????
If you use Activation = ActivateOnly, the cells will not be editable, but they will still enter edit mode and allow the user to select text for copying, and the EditMode events will fire.
