850
Setting column set in NodeLevelOverrides prevents node tree creation?
I'm binding an UltraTree to a structure like this:
   list
      list
         object
         object
This works fine. I then rebind the tree to a structure with one less level:
   list
      object
      object
This also works fine. However, if I try binding to the original, three-level structure again, I get a tree containing only a single node (for the second-level list, since the first-level list becomes the implicit tree root).
This seems to be related to some games I'm playing in AfterDataNodesCollectionPopulated. In that event, I'm setting NodeLevelOverrides to use a particular column set for each tree level other than the last one, and I'm setting the last level to use a different column set. If I disable this code, the problem does not occur.
It seems to me as if maybe the tree node creation is not working because the second-level list doesn't have all the properties my column set is looking for, or something like that. Any ideas?
   Aaron
