When I try to group over mutliple columns, the grouping behaviour is wrong.
See the example below: The "Mandant" column has only two different values (IGES and CSG in this example). The column "Projektleiter" can either be 0 or 1. However, when I group over those columns I get this strange result. Any ideas? I am using Winclient 10.1 with the latest hotfix (1027).
Hello Steffen,
Your case is with the following number: CAS-46620-R183DD. I also have passed this behavior to the developers and when this issue is resloved you will be accordingly notified through your case.
Please let me know if you have any other questions on this matter.
A case has been created for you already. I can reproduce this in 10.1 build 2027 but not 1007 so something changed between the builds. We are investigating and you should hear from our Developer Support team as soon as we have more information.
Should I file a bug report for this one?
Well, when I group over each column alone, everything is fine and grouping works. Only when I add the second groupingcolumn, I get those strange results. I can reproduce the error in a simple solution, which i attached.
I remember having problems like this myself in the past but it usually was because I didn't set the Type for the column or the column type was set to something else than I wanted which would result in odd behavior when grouping.
Did a quick look and here is the thread I was thinking that shows this.
