helloI had version 9.2, I installed version 10.1, I have no help file in the structure of visual studio, how to find these info.Thank you in advance.Guy Muller
I just wanted to know if you was able to solve this using Tom's suggestions or you still need help? Just let me know. Thank you.
Sincerely,DimiDeveloper Support Engineer, MCPD Infragistics, Inc.
Hello Guy,
Check out this forum post. It shows the steps that you can take to download the help for your NetAdvantage:
http://forums.infragistics.com/forums/p/38702/221595.aspx#221595
If you would rather not download and install the help, you can always jump on our online help located here:
http://ko.infragistics.com/support/documentation.aspx#OnlineDocumentation
Thanks!
