585
UltraGrid Won't Add New Row
I have a UltraGrid 9.2  grid that uses a BindingSource that is backed up by simple LINQ query.
The grid updates and deletes are working fine. I am having problems when tabbing off of the "new row". It is not letting me do that. I have filled in all data fields programmatically with valid data but the grid will not let me tab off of that row. If I modify any field on that row then I can tab off of the row and it is marked as dirty, therefore allowing me to save it to the database. I get no warning about why I cannot tab off of that row, it just won't do it. I can find no event being raised where I can warn the user.
Another problem occurs if I do not fill in the fields with valid data on a new row. Some of these columns are marked at not nullable. If I leave these as blank in the grid I would like to warn the user that they need to fill in valid data for that field before trying to commit to the database. Right now it just stops in the last column, not tabbing to the next row and not warning the user.
Thanks for your help.
Steven
