Hi, is there the possibility to have large images on tools added to a PopupMenuTool? Thank you.
Hi Mike, as usually your answer arrived very soon!! Thank you very much for precious info.
Yes, you can either set the PopupMenuTool.Settings.UseLargeImages to True to use large images in a specific menu tool or you can set the UltraToolbarsManager.MenuSettings.UseLargeImages to True to use large images in all menus.
