Hi
i have an UltraTree(ver8.2) which is databound and displaying multiple columns using ViewStyle = Grid,but when i dragDrop a node ,there show me a error,the error message is "Cannot reposition a node from a bound nodes collection"
i set the AllowDrag = true.
there is my code(without drophightlight):
void UltraTreeX_SelectionDragStart(object sender, EventArgs e){ this.DoDragDrop(this.SelectedNodes, DragDropEffects.Move);}
void UltraTreeX_DragOver(object sender, DragEventArgs e){ System.Drawing.Point PointInTree; PointInTree = this.PointToClient(new Point(e.X, e.Y));
afterNode = this.GetNodeFromPoint(PointInTree); e.Effect = DragDropEffects.Move;}
void UltraTreeX_DragDrop(object sender, DragEventArgs e){ UltraTreeNode BeforeNode = null; SelectedNodesCollection SelectedNodes; UltraTreeNode DropNode = new UltraTreeNode();
SelectedNodes = (SelectedNodesCollection)e.Data.GetData(typeof(SelectedNodesCollection)); SelectedNodes = SelectedNodes.Clone() as SelectedNodesCollection; SelectedNodes.SortByPosition();
if (SelectedNodes[0].Level == afterNode.Level) { for (int i = 0; i <= (SelectedNodes.Count - 1); i++) { BeforeNode = SelectedNodes[i]; BeforeNode.Reposition(afterNode.Nodes); } } else if (SelectedNodes[0].Level > afterNode.Level) // { for (int i = 0; i <= (SelectedNodes.Count - 1); i++) { BeforeNode = SelectedNodes[i]; try { BeforeNode.Reposition(afterNode, NodePosition.Next); } catch (Exception ex) { MessageBox.Show(ex.Message); } -----> here } }}
thanks~
Can you provide an example for option number 2? I've done that and I am able to change the underlying data, but I cannot make the Ultratree resort itlself without rebinding it.
Let me know if you need further assistance for this and I will open a support ticket for you.
- Stefaniya
The error message here is pretty clear. The tree does not support repositioning bound nodes. So you cannot do this if your tree is bound.
You can Submit a feature request to Infragistics and perhaps this feature can be added in a future release.
For now, there are a couple of things you could do:
1) Don't use the tree bound, but instead populate it manually.
2) Use a hidden column to sort the nodes and adjust the values in this hidden column such that the nodes are in the order you want.
