I'm trying to use Infragistics3.Excel.v10.1 (10.1.20101.2018) to load an excel 2010 spreadsheet, but I keep getting an ArgumentOutOfRange exception:
"Index was out of range. It must be non-negative and less than the size of the collection. Parameter name: index Actual value was 0."
This is in a winforms VB.Net 2010 project, using .Net 4.0. As I understand it, the XLSX format is the same for 2007 and 2010, so shouldn't this work? I get the error with any XLSX file.
The stack trace of the exception is included below,
Kev
Stack Trace
at Infragistics.Excel.WorksheetCollection.get_Item(Int32 index) at Infragistics.Excel.Workbook.OnAfterLoadGlobalSettings(WorkbookSerializationManager manager) at Infragistics.Excel.Serialization.Excel2007.XLSX.Elements.WorkbookElement.OnAfterLoadChildElements(Excel2007WorkbookSerializationManager manager, ElementDataCache elementCache) at Infragistics.Excel.Serialization.Excel2007.XmlElementBase.LoadChildElements(Excel2007WorkbookSerializationManager manager, ExcelXmlNode node, ExcelXmlDocument document, XmlReader reader, ElementDataCache elementCache, List`1 elementCacheCollection, BeforeLoadElementCallback beforeLoadElementHandler, AfterLoadElementCallback afterLoadElementHandler, Boolean& isReaderOnNextNode) at Infragistics.Excel.Serialization.Excel2007.XmlElementBase.LoadChildElements(Excel2007WorkbookSerializationManager manager, ExcelXmlNode node, BeforeLoadElementCallback beforeLoadElementHandler, AfterLoadElementCallback afterLoadElementHandler, Boolean& isReaderOnNextNode) at Infragistics.Excel.Serialization.Excel2007.XmlElementBase.LoadChildElements(Excel2007WorkbookSerializationManager manager, ExcelXmlNode node, Boolean& isReaderOnNextNode) at Infragistics.Excel.Serialization.Excel2007.XmlContentTypeBase.Load(Excel2007WorkbookSerializationManager manager, Stream contentTypeStream) at Infragistics.Excel.Serialization.Excel2007.Excel2007WorkbookSerializationManager.LoadPart(IPackagePart part) at Infragistics.Excel.Serialization.Excel2007.Excel2007WorkbookSerializationManager.LoadPartRelationships(IEnumerable`1 relationships, ContentTypeBase contentType) at Infragistics.Excel.Serialization.Excel2007.Excel2007WorkbookSerializationManager.LoadWorkbookContents() at Infragistics.Excel.Serialization.WorkbookSerializationManager.Load() at Infragistics.Excel.Workbook.LoadXLSXFile(Workbook workbook, Stream stream, IPackageFactory packageFactory, Boolean verifyExcel2007Xml) at Infragistics.Excel.Workbook.LoadHelper(Stream stream, WorkbookFormat format, String parameterName, IPackageFactory packageFactory, Boolean verifyExcel2007Xml) at Infragistics.Excel.Workbook.Load(String fileName, IPackageFactory packageFactory, Boolean verifyExcel2007Xml) at Infragistics.Excel.Workbook.Load(String fileName, IPackageFactory packageFactory) at Infragistics.Excel.Workbook.Load(String fileName)
Thanks! This helped me.
Hi Matteo,
That seems to have done the trick, thank you
Kevin
Hello Kevin,
Do you have any more questions on this matter?
Sincerely,MatteoDeveloper Support EngineerInfragisticswww.infragistics.com/support
Hello Brian,
Yes, I was able to reproduce the issue, and I have logged this with our developers.
