hi,
Is it possible to generate acroforms?
I don't believe that there is any support for this in the current Infragistics Documents engine. You should Submit a feature request to Infragistics
hi Mike,
It's the name for pdf forms.
AcroForms were introduced in the PDF 1.2 format. AcroForms permit using objects (text boxes, radiobuttons, etc.) and some code (Javascript)
I like to make pdf reports where we can use text boxes and digital signature implemantations.There some free implementations but then I need to make and custom converter for my reports. lots of work so before beginning maybe I overlooked it in your document.dll
thanks
I suspect probably not, but I have never heard of an Acroform, so I can't be sure.
