I want to apologize for the silly question, but is there some way to have UltraGrid with applied read-only behaviour (through preset) but make only one column editable(because it contains check boxes and i want to be able to check them)
Thanks, Maria
Thank you for the answer, it was very helpful
Hi Maria,
Which preset are you using? A preset just sets properties on the grid. So could load a Preset into the grid and still change some of those properties to suit your needs.
What I would do in a case like this is - don't disable editing in the grid by setting AllowUpdate (which is probably what your Preset is doing). Instead, disable each column individually, except for the CheckBox column.
Here's a KB article that goes into some detail about all of the ways you can disable editing in the grid.
HOWTO:How can I make a grid or a column, row, or cell in the UltraWinGrid disabled or read-only?
