does anyone know if it is possible to check if the CTRL Key is being pressed in the DoubleClickRow Event?
regards
Stefan
Thanks it worked fine.
You could try the following:
private void ultraGrid1_DoubleClickRow(object sender, Infragistics.Win.UltraWinGrid.DoubleClickRowEventArgs e)
if(Control.ModifierKeys==Keys.Control)
MessageBox.Show("ctrl pressed");
else
MessageBox.Show("ctrl not pressed");
Other way is to use the KeyDown and KeyUp events and check when the Ctrl key is pressed and released as the DoubleClick event should fire between.
Let me know if this works in your scenario.
Stefaniya
